Rogue Racing NEW cantilever and J Arm setup
ntm
Alberta, Canada
The front J Arm looks deceiving in the picture. You cant see the cross brace that runs behind the radiator.
I was speaking of the rear.
Nice job thinking outside the box, it looks great !
Is the pinion angle controlled by the rear j arm, or is there a third link hidden up in there ?
And on the front, how much wider did you go over stock ?
The shocks must be darn close to a 1:1 ratio with them pushed outside of the stock coilover bucket, no ?
So full of questions I am.
You would have saved me a lot of trouble if you'd brought out that rear setup a few months ago, lol.
Rogue Racing
I was speaking of the rear. Nice job thinking outside the box, it looks great ! Is the pinion angle controlled by the rear j arm, or is there a third link hidden up in there ? And on the front, how much wider did you go over stock ? The shocks must be darn close to a 1:1 ratio with them pushed outside of the stock coilover bucket, no ? So full of questions I am. You would have saved me a lot of trouble if you'd brought out that rear setup a few months ago, lol.
The front is 7" wider than stock F-150
The center J arm controls the pinion angle
The trailing arms (outside links) have a 7" spread from frame mount to axle.
12" Coils & bypass front & rear
1.5" dia pac sway bar runs through the oem frame brace.
5.0 cyote, whipple & borla 750hp. Tuned by Shelby
Palerider
Green is the buzzword. I'm green with envy and pissed that I don't have enough green for this right now.
Sent from my SM-G925V using Tapatalk
Jimbo
Mad Frog Mattis
IL
