Things that don’t work on Gen3 2023 Forscan
Renomaan
First off… Why isn't there a Gen3 Forscan area?
I’ve tried changing the following and the 2023 won’t take the changes, everything is back to OEM build after entering codes???
Auto start stop disable- it worked for a half hour then reverted back
Bambi mode—-the codes were already from the factory as the spreadsheet recommended—-no change possible
Disable seat belt dinger—- this took !
Stereo gain mod—-this did improve the entire sound
Has anyone got work around for any of these on an 023 Gen3
HighwaySentinel
︻デ┳═ー - - - - - - -
California
There's a long long thread specifically focused on gen3 Forscan. You'll get more answers in there. 85+ pages if my memory serves me. But, what the heck...we can always use another one.
T4RNewbie
Tejas
found under electrical?
Idaho
Start/stop diable requires you to disable two settings. The second one will eliminate start/stop but the battery indicator light on the dash will stay on b/c it affects the battery management system.
IPC: Auto stop start: Disabled (enabled default)
BdyCM: BMS/Auto stop start Disabled (enabled default)
Keith88
Boise, ID
Tell me more bout this stereo gain mod...... PLEASE
HighwaySentinel
︻デ┳═ー - - - - - - -
California
Start at post 825. Seems to be a Gen2 thing. At least according to @Antho . If it worked for Reno on his Gen3, @BIGW0RM will be happy.
R
Renomaan
I’ll try the auto restart again, I made both changes and the dash light def turned off but not the function.
Seems the 022 codes don’t work on 023
Prob why goosetuned doesn’t have a tune for 023 either..internal changes
t4arghhh
CA
I spoke to Goosetune as he did my last truck and was inquiring on doing the 23. He said its simply a security lock on the ECU that needs to be opened up to allow for tuning.
