Best way to wire 6 pods?
McCarthy
Canada
Any suggestions on the best way to wire 6 Diode Dynamics SS3 Pro's to the upfitters? (Will be mounted on a foutz motorsport bumper bracket) I would like all 6 to be on one upfitter.
The only wiring harness they sell for 2 of the lights, perhaps buy 3 double harness kits and splice them together? Or does anyone sell a wiring harness for multiple pods?
I will have a shop do the wiring as I have zero patience so wiring is imaginably not gonna happen for me lol, but want to have the right parts on hand so it's done properly.
Thx!!
Nex
RIP CoronaRaptor
Washington State
JayRods
Manteca Ca
JayRods
Manteca Ca
Also I wired 2 separate relays trigger wires up to 1 Upfitter switch, so I can split the load from the 6 light in half, 3 lights on each relay, and only using 1 Upfitter switch to control them all.
Chop96
Fredericksburg, VA
4x4TruckLEDs.com
Thx!!
We actually make a triple harness for that. It puts 3 pairs of lights on 3 switches. It's all in one
SS3 without backlighting: https://www.4x4truckleds.com/crysta...ors-diode-dynamics-rigid-industries-morimoto/
SS3 with backlighting: https://www.4x4truckleds.com/crysta...arness-6x-dt-4-pin-connectors-diode-dynamics/
If you want them all on one upfitter... easy. Just twist the 3 upfitter wires on our harness onto your 1 upfitter
People LOVE our harnesses.. basically best you can get. Plenty of length so you can route the wire how you want. The entire harness is protected with a braided sleeve as well. Weatherproof heat shrinkable wire connectors already on the ends as well and each circuit is labeled.
1 leg (black) for ground
3 legs for each pair of lights
1 leg for the back-light circuit
Twist A B and C together, put a new wire connector on. DONE. Easy peazy
