GEN 3 Official Aftermarket Wheels Thread
22R37
staten island NY
Does anyone have any good recommendations on where to get the factory forged wheels? I wanted to add that option but the allocation and order they had for me included the base wheels. I can't find them anywhere online, and my dealer said they can't add them to the order.
Are you interested in wheels only or wheel-tire combination?
Pacific Wheel
Pacific Wheel
Reno, NV
If anyone is interested in a super inexpensive set of wheels these just got reduced again. PM for info
Pacific Wheel
Pacific Wheel
Reno, NV
Any chance of getting a PM for pricing? Want to reuse my stock 37PP tires and would like to retain the stock offset as much as possible. Is Black the only color or does it have a carbon gray option?
Black only, currently on backorder and the only offset they offer will come out 1.5" from stock. If you're good with that I can PM you a quote
AustinRaptor512
Austin
Anybody have problems with vibrations after going aftermarket on wheels? I recently upgraded to 37” BFG KO2’s and Method 705’s and the ride is definitely stiffer/bouncier. Took them to two separate tire shops and both said that they’re balanced. Same load rating tire as my 35’s. Ride on the 35’s was like butter compared to this.
Pacific Wheel
Pacific Wheel
Reno, NV
@AustinRaptor512 not any situations I've seen where a wheel would change the ride quality unless you were experiencing vibration which could be from an out of round wheel.
Have you messed with the air pressure? Technically the OEM 315 has a load index of 113 (2535lbs at 45psi) as where the OEM 37 has a 116 load index (2756lb at 45psi). They're both load "range" C but the 37 is setup for slightly higher weight. The 37 could benefit from a little less air pressure but all of this info aside they should be very similar.
AustinRaptor512
Austin
Running 35psi all the way around. Love the way it looks, but miss the ride quality on the OEM 35’s. Thanks for the info!
Staff online
93,423
56,706
marquez47
