Problem
choppersando
minneapolis
So I was taking a left turn and heard a pop and immediately following the truck felt super wonky so I stepped out and noticed my driver side bolt on the panhard bar broke off. Called multiple ford and apparently they don’t have any of these bolts left in the country. Any advice from fellow raptor owners? I’ve included pictures
FordTechOne
Detroit
That is an extremely strange failure; is the truck modified? It looks like the bolt is missing completely; did you find the sheared pieces or is it just gone?
C
choppersando
minneapolis
I’ve been searching for the bolt on the corner I took and cant locate it, it’s like it vanished. And the truck modification wise only has perch collars and wheels/tires
FordTechOne
Detroit
So only the front was lifted, nothing in the rear?
Per the parts catalog, the bolt is an M16 x 97mm. So I would try and find one in the aftermarket with a nut until you can get an OEM one. It just needs to be a class 10.9 (strength).
