Live Valve Issue? Rides Harder than Gen 2
NHDude4
NHDude4
Southwest, NH
check the ssm in the clunk thread
This isn't a sound or suspension clunk. It's a physical stiffness when going over bumpy roads. I read all about the clunk and saved the relevant info on it before my truck was even delivered (in case mine was affected). My build was two days before the cutoff for that, but I don't think my complaint is clunk related.
ray0409
New Jersey
What about the offroad mode? On bumpy roads, my 35 gen3 is also jiggly in the offroad mode. The difference between the three modes is very small to me.
NHDude4
NHDude4
Southwest, NH
I agree off road mode seems a bit more jiggly and the differences between modes is small. The firmness I'm experiencing is in Sport suspension mode and is only worse in Normal and Off-Road.
ray0409
New Jersey
The sport mode doesn't even feel firmer on my raptor. My tire pressure is 38 psi. Maybe I should lower it to 35 psi. I believe the tire noise is gonna be crazy
NHDude4
NHDude4
Southwest, NH
I notice very little tire noise from the stock tires and I've been as low as 35psi. Didn't seem to change the ride much though.
tm965
NOVA
if youre running the k02s, it's not going to be noisy at lower pressures. 38 is too high and will ride pretty terribly. try 35 front, 32 rear and you'll see a world of difference.. to the extent that you'll realize sport mode is way stiffer than the others
ray0409
New Jersey
The build quality of my raptor is not good. I noticed very load road noise on the first day. Dealer did not help so I bought lots of sound dampening materials and reduced the noises.
RaptorIce
Dinuba CA
Yes. It is softer over some road surfaces but also has the most body roll. I guess I'm looking to have my cake and eat it too, and I expected the live shocks to be better at that. Mostly just want to make sure it is what it is and not that I have a shock tuning issue.
This has made a night and day difference for street ride. Off road I'd say its meh to good but iv only off roaded with it once.
beachz
Monument, CO
BOOM! Found this link and tried this in FORScan. There’s one minor difference but the software had a clear explanation for the procedure to put the live shocks in engineering mode. Just took it for a ride on a rough road and it’s a pronounced improvement!View attachment 373496
Just read your post on the forscan thread and bookmarked the link. Great find/clue and thanks for sharing!!! This will be very valuable once springs settle in and a great service check!
93,171
56,440
jumpcutter
