The dealer needs to follow the pinpoint test for the DTC. If the pinpoint test lead to sensor replacement then they need to use the appropriate flex probes to inspect pin fitment at the PCM and sensor connectors.Thank you. Sucks that ford just changed the sensor. Is there an easy way to diagnosis where the wiring or pin fitment issue is?
