New Owner-35x12.50x20-Will it fit?
agerman
houston
I am ordering some wheels for my raptor and curious if - 35x12.50x20 Nitto Ridge Grappler will fit on a stock (35 model) raptor when mounted on a method 20x10 +18 without any trimming? The truck will be leveled with the RPG collar.
RamseyF
michigan
you should be fine I put 35x12.5x20 ridge grapplers on fuel 20x9 +19 offset. Vapors on my stock no leveling kit 2018. sits out about 1/2 more than stock. I think no problems what so ever. what did the tire shop tell you. just need to be carefull with the offset.
RamseyF
michigan
check this out. you put in stock and new combo and you can tell how much it changes. should help you a lot. try to play with the offset to keep as close to stock as you can to avoid issues. obviously the tire size is pretty much stock size.
A
agerman
houston
I didn’t buy any yet as I wanted to confirm with the forum first. One guy said the Gen 2 only required a little plastic trimming to fit the wheel and offset. It sounds like we should be good so I appreciate the feedback.
RamseyF
michigan
if you dont have the info the original wheel is a 17x8.5 +34 offset.
I didn't have to trim anything with my combo
dillard09
College Station, TX and Socal
I ran 20x9 Rotiform Six-OR on some 37x12.50r20 General Grabber X3s and they did rub a bit a full lock when hitting a bump but nothing to serious. I believe the Rotiforms are +1. I had 1.5" RPG in the front. Here is what it looked like.
Also seen you are in Houston im in College Station. .. just throwing it out there. Those 20x9 Rotiforms you see on my truck are for sale if interested. They are in the for sale section.
A
agerman
houston
I appreciate all of the feedback.
On the wheels for sale, Let me take a look and will then contact you if I think it would work for me.
