Ignition coil replacement problem
Donovan
DC
I had a similar issue when I tried to change plugs on the other side of the engine. **** got brittle.
I will now WD40 those types of connectors and etc prior to having to pull on them.
CoronaRaptor
CoronaRaptor
CANADA
How much did your coils run you? Was going to order them through a dealer near me but they wanted $200 EACH.
Check out rockauto, they even just posted on here yesterday with a discount code, I just posted the part numbers and prices on "what did you do to your raptor today", but here it is:
7378719a-361b-44ca-82a9-c414c4884806-jpeg.322674
And these are the OEM ones, they have cheaper ones, but screw that, I got oem.
CoronaRaptor
CoronaRaptor
CANADA
here is the discount code thread
Big Papa Gecko
2012 Raptor SCREW Tuxedo Black (Sold)
Vicksburg, MS
yeah, 700 before discount code is alot cheaper than 1600 haha. Thanks
MRV99
HOme
I guess I will pray mine don’t spin when I take them off, will do that in the morning.
I have a feeling it happened because there was still some heat in the head and the plastic was warm enough that it allowed the nut to spin. If it is cool, I would assume it has a better chance.
CoronaRaptor
CoronaRaptor
CANADA
Well the good news is, I got all 8 coils disconnected and unbolted, just the 2nd bolt from the drivers front was rusted in place a bit, so will be putting a little dab of never seize on these before I put them back on. Now I can finish detailing the engine and get started on changing the plugs.
93,224
56,503
DehydratedSurfer
Latest posts
