Alternative High-Beam Connection ?
2020Raptor
South Central...NJ
Happy Friday.
I would like to activate my BD S8 light with the high beams.
But per FordTechOne, one should not tap into the lighting circuit to power a relay.
BCM issues down the road.
Question:
So then how to otherwise activate my S8 light with the high beams ?
Solutions ?
Is there a non-contact sensor that connects to a relay or such ?
Kinda like a tick-tester.
Or how else to git-r-done ?
Deep thoughts appreciated.
Thanks very much !
2020Raptor
2020Raptor
South Central...NJ
Below are a couple of ideas.
I would appreciate thoughts from @FordTechOne or anyone else knowledgeable.
Idea 1:
Can we tap into the low-power side of the high-beam relay to also trigger a second relay ?
Idea 2:
Can we tap into anything related to the fog lamps that are on the swankier models ?
Fog lamps go off when high beams come on.
If the wiring is the same, perhaps there is something that we can use.
Fingers crossed.
Thanks very much !
pat247
Oklahoma
Come on guys, it aint rocket science. Tap the idiot light that tells you the high beams are on.
FordTechOne
Detroit
Idea 1:
There is no high beam relay. The high beams are powered directly by an Field Effect Transistor (FET) in the BCM.
Idea 2:
Fingers crossed.
Thanks very much !
Possibly, but you’d have to figure out if the harness connections are actually there. Regardless, the fog lamps are driven by the BCM, so you’d have to find a way to reprogram it to recognize an input (switch) and provide the voltage output.
