CoronaRaptor
CANADA
Sounds like it’s just below the dash tray/center speaker...
You can but the drivers seat back all the way and contort like a gymnast and reach up with a flashlight and see the motor, put your hand on it when it clicks and see if that's the one, otherwise the other two are not easy at all. I've done this one on mine, so was easy.
BenBB
Lots of different places
Many thanks, will do! Does that one control side-to-side or defost/vent/floor or heat/cool?
Jakenbake
This was the one that went out on me. The symptom was no ability to adjust passenger temperature. Also can’t remember if we lost any other adjustments. Was pretty easy to remove the touchscreen and trim panels. Took a few hours.
fitzmotor
Saugus, Ca
Well because it just hit 130K, which is where I have seen some of the basic electronics start to have trouble, I ordered cam and crank sensors, fuel pump and fuel pump driver, both upstream 02 sensors, all OEM, and a set of coils, I went performance aftermarket on those.
I may have start doing long hauls, I figured I would replace the basic stuff.
As well as tensioner kit/pulleys, A/T fluid and filter, oil + filter.
Dropped a frickin fortune, but it's the OEM stuff that pushes the cost up, but I've been stranded multiple times with brand name aftermarket electronics.
I'll be busy when it all shows.
GWBush
Houston, Texas
Just heard the dreaded blend door click click click...:rage:
So I’ve searched on this and understand it’s something to do with driver/passenger air temp I gather. What is the “click click” you hear?
121k miles and want to be aware of something to look for. Fixed Fuse 27 last week
