Passenger side carpet wet!! Where is the drain for the AC???
RaptorFun
Northeast Wisconsin
Ford issued a TSB for this issue. Unfortunately...I don’t have the document number handy. Do a forum search and you’ll find it. It appears a number of us have run into this problem. Not good...
Doctor Mike
NJ
This may not be as easy as just the AC drain. I have a 2018 Model. Noticed an actual shlussing sound of water coming from right passenger side. Thought at first it was water in the door but no, water was IN floorboard. Carpet on passenger side soaked and backseat as well. Brought to dealer. Again had hard time diagnosing one of the many problems I have had with this vehicle . Turned out to be a leak between the bed and the cab. Required all new carpeting. See if rear carpet is soaked as well
FordTechOne
Detroit
How can you have a water leak between the bed and the cab when they are not attached?
93,171
56,440
jumpcutter
