Jurasick
Has anyone replaced the three red leds that come on the gj brake light? They are so dim. Would love to retro some brighter leds in there.
The housing is aluminum and can easily be drilled out for larger led. Just don’t even know where to look.I'm friends with TJ from GJ Motorsports and this question has come up before but those LEDS are the brightest available based on the size parameters.
They are just normal red led lights. With the brake on they are sent 12v, with just the parking lights I believe it’s 9v. So it’s just more voltage that makes them brighterwondering the same myself. but these leds are dim/bright mode? and i dont think there are many leds out there that have this?
Do you have a picture of it at night by any chance?I have the Evil Manufacturing 3rd brake light and the red leds are bright! Maybe you can get a set and install them on your light.
the parking lights are probably around 8v. if it were 9v, things would be much easierThey are just normal red led lights. With the brake on they are sent 12v, with just the parking lights I believe it’s 9v. So it’s just more voltage that makes them brighter
It literally doesn’t matter. The leds are 12v. Feeding them less voltage makes them dimmer and when the brakes are applied they get full voltage 12-14vthe parking lights are probably around 8v. if it were 9v, things would be much easier
