Wileecoyote
Nova Scotia, Canada
Catching up from the weekend -
Installed the Husky wheel well liners. All the reports about them being a bitch are true. Work Gloves recommended. Knee pads too.
Leaving them in the sun in driveway previous made them a little more flexible, but by the time I picked them up, slid them over the wheel and got to work, they had cooled to ambient temperature, so it really makes no difference leaving them to heat up. My heat gun did come in handy fitting the edge between the fender and flare though.
Still doing pulls for Goosetuned and sending them back to him. Truck is really waking up.
Clinsta
Eibachs installed. Stance looks great now. I measured fender well arch to the ground on the front and the rear 1/16” difference with 3/4 tank of fuel. The steering and front suspension are definitely more firm than before, which I’m really good with. Took it out to the ranch last night and made a couple of high speed passes in Baja Mode and it is still an incredible ride! Thanks for all of the great info on FRF!!!
Comish
New York
I did my first at home oil change. Went pretty okay until I got to the filter. I thought the filter was positioned above what can only be described as a thoughtfully positioned drain trough. This is not the case. Lessons learned. I still wonder what the plastic drain is for.
CHMP
Santa Cruz
Good news: Still have ford pass reward points so outside of buying my amsoil the oil change was free.
Bad news: I'm a lucky winner of failing cam phaser(s). I'm surprised as I thought since my truck was an early 2019 build it was sorted out. Dealer said they would need the truck for a week or two. They are probably factoring in the parts getting ordered / arriving. Hopefully I can drop it off for only a day or two as I thought it was a ~6 hour job.
