Raptor seems too high for city garage
rayofsi
NYC
... i'm in NYC... i have to find a garage to fit hah. Doesn't help that my Raptor is leveled and slightly lifted.
4rdFan
Michigan
I would definitely leave the factory antenna if you're going to be in/out of parking garages. I bought a stubby and then quickly realized that it was a great early warning system.
I park in a 6'8" garage and fit, the satellite antenna is pretty close though... it's a bit sketchy, but just go slow and you'll be fine. I would recommend going to whatever garage you plan to park in at night, or a weekend when it's not busy. That'll give you time to check everything out slowly, without people freaking out that you're blocking an entrance.
I've tried 6'6" and that was too low for me to get in. Just be careful!
Can confirm. I've also parked in an underground garage that was labeled 6'8" with no issues (stock antenna swapped out for a stubby).
ADY
USA
I run in to the same with most older parking garages in the San Francisco bay area. I avoid anything that isn't at least 6'10" or higher just b/c they might have new asphalt, low hanging fire sprinklers, and inclines where the long wheelbase may result in the truck actually sitting higher. At 6'10" you'll be scraping the antenna on every concrete beam, but in the city you don't really have another option. I keep the factory antenna as an early warning.
I loved drone
Seattle
I live in Seattle and have parked my truck in garages all over the city. I’m not sure what garage you’re parking in but 6’-8” is not code for a garage lid height. 7’-0” is minimum. Maybe it’s in a really old building? Don’t worry about the antenna. You might want to forget about the light bar.
NeoLeo
Ashburn, Virginia
I commute to Wash DC where my garage ceiling height decreases as you go to lower levels - even though the entrance may be high enough. Be careful about that.
Kiwi Raptor
Long Beach, CA
I park in a garage at work (Los Angeles) and have 6'8" clearance as well. I removed my OEM antenna and replaced with a stubby due to the constant noise it was creating when it was hitting the concrete beams.
It is a tight fit, but does clear with about 1 1/2 in to spare. I also open my sunroof screen so I can keep a watch up above as I progress through the garage.
Lastly, I have added a label near my mirror to remind me of my clearance height when entering unknown garages.
My GTi is my everyday drive and that is fun in tight spaces.
FirstTruck
California
I swapped my antenna out for a shorter 27 inch one... less false alarms with clearance issues. If that antenna hits then I know I shouldn't go any further.
FastEddie
Yup. Before going anywhere in the city with the Raptor I plot out exactly where I'm going to park and what the clearance is.
Have a friend who had a lifted Ram HD that he left at a garage and they did several thousand in damage to the roof of the cab parking it where it hit some pipes in the ceiling of the garage.
Don't want anything like that to ever happen.
93,224
56,503
DehydratedSurfer
Latest posts
