Oil Filter Replacement
JohnC12
Leesburg, VA
I just did my second oil change on my truck yesterday. For the most part, it was pretty easy - especially after adding the Fumoto drain valve during my first oil change. But the oil filter... what a pain to get off!!!!
I can't get more than one hand in from the skid plate, and accessing from the top isn't much easier. My biggest issue is that I need two hands to use either a band or jaw wrench. The Harbor Freight piece of crap oil wrench I'm using gets stuck on the filter - so tight that I need to use a hammer to get it off.
Out of curiosity, is anyone changing it from the top of the truck rather than the skid plate access hole?
What are you guys using to remove the filter? Band, fluted wrench, etc? If you're using a wrench style, what brand?
Is anyone removing the hard plastic hose that practically sits up against the filter?
goblues38
STL
bottom.....no tool......hand tight, hand remove.
make sure you put some oil on the gasket before putting it back on. after 2 or 3 changes, you get the hang of it.
JohnC12
JohnC12
Leesburg, VA
Thanks for the info! I usually barely tighten with the wrench... usually 1/8 turn after hand tight. Not anymore. And I always put a little oil around the gasket.
I'll give the hand tighten a try next time around.
Refugio
South Texas
From the bottom thru the access.
Done it twice by hand.
Hand tighten back on.
Also installed the fumoto drain valve and that alone eliminates a lot of mess.
JohnC12
JohnC12
Leesburg, VA
Thanks! Yeah... LOVE the Fumoto drain valve... so much easier and no mess!
I installed the Fumoto F107SX SX Series Drain Valve
SilverBolt
Hired Gun
Portland, OR & Eureka, MT
I've been thinking about dropping the entire skid plate. How much of a pain is it getting it back on?
4-bolts. Super easy. I am doing it with all four tires on the ground. The first time I just removed the little access panel and fought it like crazy. From them on I just drop the the entire skid plate. Access is much easier. Also gives you a good opportunity to see how everything looks and check for leaks or damage.
