JohnC12
I just did my second oil change on my truck yesterday. For the most part, it was pretty easy - especially after adding the Fumoto drain valve during my first oil change. But the oil filter... what a pain to get off!!!!
I can't get more than one hand in from the skid plate, and accessing from the top isn't much easier. My biggest issue is that I need two hands to use either a band or jaw wrench. The Harbor Freight piece of crap oil wrench I'm using gets stuck on the filter - so tight that I need to use a hammer to get it off.
Out of curiosity, is anyone changing it from the top of the truck rather than the skid plate access hole?
What are you guys using to remove the filter? Band, fluted wrench, etc? If you're using a wrench style, what brand?
Is anyone removing the hard plastic hose that practically sits up against the filter?
