Gary E
Medford, Oregon
95k. Picked it up at 55k. Previous owner was a boat enthusiast so I’m pretty sure it spent a lot of time towing shit.
2014 with 32K on original springs and tires with 8/32" tread remaining currently sits at 42 3/4", so with new KO2's it would be sitting at 43 1/4". With your Deaver +3 that's +1 1/4" difference which is about right.
Chiefapple
Milwaukee, WI
Right. Except I had a 1” drop shackle also. So it should be at stock. Like I said though. My stock height when I picked it up was 43.5-44.0”. When I measured it last week it was 42.5-43.0”. So I guess it was closer to an inch of sag since I picked it up.
allinon72
Indianapolis, IN
Thomas_JohnDoe
Chicago
Put the 37’s back on. Found my driver side tie rod was very loose on the Camburg clevis. Disassembled that, used red locite and got it fixed. Cleaned all the grease from the ripped CV boot that was everywhere
And it looks like my front diff is leaking
At least your front housing is not cracked .... with 30K
speedfourfan
I installed a Corsa xtreme today that I got a great deal on from Rick@freedommotorsports. I have ran several different brands and set ups of other exhausts and I can can say without a doubt this is the best! I should have just went with corsa right away and saved myself a bunch of time and money.
Sent from my SM-N960U using Tapatalk
Anthony k
Michigan
That needs some tweaking. It should line up with the body line somewhat
