Installing 40 inch nitto tires ( re gearing
BlueGoliath96
BlueGoliath96
Looks good! How does it cycle?
It’s looks badass but you sacrifice handling it doesn’t handle as good as the Mickey Thompson Baja atz p3 that one was 37x12.5 , did some mild off-roading loose sand the truck moves from side to side maybe becuase the tread on that nitto is soo frickn wide 13.5 and at the highway there is some steering wheel movement (vibration ) not crazy
BlueGoliath96
BlueGoliath96
Here is a height measurement after the 40s from ground to top of the cab ik jaw dropping for a raptor lol
TheButcher
The tread pattern on that tire is your biggest issue with handling. The lugs aren't perfectly round on there, so you get some wobble from that. The best riding 40" mud tire I've seen is the Toyo MT. I know you already dropped the coin on these, but going with the Toyo would improve the ride considerably.
BlueGoliath96
BlueGoliath96
57cb819edb8e5f9be40668a864b50520.jpg.
REGEARING process front went with nitro Master kit
500mag
Georgia
Or, the KM3s in 39 x13.5x17
BlueGoliath96
BlueGoliath96
Heard very positive feedback from this brand , I’ve changed the front with Motorcraft and the rear with Amsoil , after the first 500 miles I have to change the rear once again [emoji1303]
