BuiltRight Industries Bedside Rack System Show Me Your Setup!
bigrig
San Jose, CA
I am happy with the setup. I have done some offroading and hit some speed bumps at 40 and the jack stays in place. No jumps. Built right now has some bolt on mounts that would be more secure.
Good to know! Thanks for the knowledge. I may go with adding the hi-lift to mine; I have some hi-lift specific mounts I can add to the bedside racks.
Here is my setup currently...
eoCIxY-3qYf0sAR4GDBuFHF8AqNpBga8tSOc0TxGcX5APb5JW4NHQ5nlaJSoMCzrZ0qIVA3DiJdLCbZORlkkIeTejGFqJTth4esuEXCK2_2j6t49eSkeeLOHG0jaEygHEz_Ed8R3rdQNoaTyx_4CmOC7ouHTTgq6yyFvMUwQATGgpb3_uza5gFhRhMog-8I4xvevqQQutARE_Cb3QkRVwekOES56-LqIsp01NYNeZD6H7oBQbwI0ZCCuGT7LWMvzzNioL7uUIM-WeyE4V27fVUpL1yno1CWDL_lHmBPS8aefewJoOn6x9fS0F2zfTUt5m7FzHs61OhzrhAbAZsAiA9MLxEKP7EclFR-WT0FBPCfB6K57RGg_6irIi6PtnMzC3TGjXqM3eh4SYRC2WjWD2aT7sudu-v7uS6RDZbCZdJgtsfvSHsUm9h0p9AT3o4Ph2x8SXLsYQWt2eCJq-31Ss8fGXFVuIrjw4rznsX2mV3vd3qnnrB2ArrakzQIMNqgoyRbSOqb5dFvIrARwN96j_hkJRasMKXAL4J4sVmrO09RtPznTzBI9Om7zF8rO5U8y57QD9YPfDQZbK35_aft2ydBwf2aGjH4cTcxM2LlF9sr7_tvEVdYsiqczyFhsuHlvCvhyxpqQR9WqkmLsVIEwADtdRg=w1407-h1057-no
CIjcmusI09dGROwtiYCGjtExhsSesM6BFIRN4eSZxPCKxq67bogmhb4pIxvb31XdFju6M7goxt2qwCHMbPypZBzY4iWhQKq1CamqwZiayHjLjFTQVDiwEFE_GvML3mPKzikx7Ybfxea2I_5GFRTpFYG1HaYUeU2RWB_lL0VL-WLMXbURDWZYMHdTH84fg_7ArfGOlRhxu2uR_IPh8QJwidul6i_14-TEpXX_li3eaNKSLvgKJSO2Gc8edzmW-W1zJjBQ0F9UPfJ34kFHqsqCTBHQTBy4pY6u7q-L7kUaKups9zgWWohJYtp8ZIgsxhtkfbW722m2Q_ccxasWz8rx0dfUNZ4yytxautCIA8fJGN0AQv0LOpLG4Lookv-xCbcb8ln-Zu110tZWUTEt7O3NBzXAc7wnllDNLZC3IRA6oYcpwgYKVAPYoNEHq8I_5JbGLWdsX-kIEUzOZyUstJWlA0MpwlvLToAMF7BZJHTrpYNuqIJpv8jhgSZ_ie7o9FSyc65ytdjjLg32VBTw2sjJ5OrrMTzKXJs-hv4l9tuP5dMPE2nbr2e5B0ES2g-gdbFa6Vd3IjYRirMBtfrmBpJ96BY-ho0Ht8v5pgwrWs5F0qK7fgybPeyxRRdqZ6LlzSH1qemMSafxJiJCGmnwt1khaUFn1Q=w1381-h1055-no
TigerRaptor
Baton Rouge, LA
Great looking setup. I like the Tire and Rotopax mounts. Gives me some good ideas.
SnowDawg
Bigrig. What is your extinguisher setup? I've been looking and that looks like a good setup.
bigrig
San Jose, CA
I used a Drake fire extinguisher mount. To get it to stay put, I cut a piece of steel flat bar 1/4" x 1 1/4" to a length where I could match it up with the screw holes on the Drake mount. I drilled matching holes and sandwiched the bedside rack between the two.
The Rotopax needed some extra support when you go 3 deep. I created a mount that bolts to the bed where I can secure them in another location while still using the bedside rack. I attached a better picture of that below. I posted a DIY thread for the tire carrier/chase rack in case you want more info on that.
Y9w4Ofwfi7XM8cBWQgbIr_V4g9_WdwOLwqQq8n1J0e2wFsXkkf9ZWWmtuo4SRaIq5jShY1NNwvZu7RRqwgmJL-9ZDLw8z02EG082kQpUcrHqLQTFgFM_dMmFcWZdC_MozmFSEQnBrNVp9SLKzTJZ9_hw0JPj9qetC7DQX_hwh5Fo6q_Fs2-sAxDuVZbxggB8NMhscW96_aQCbI32X9WK5RykhEV6CSp5UDFezwba2qfH-MVwi2aFTeU-W9G2KQPVgEeDNa6KIweYjg9H-jDO3q22ZNkaNcpufMGUO2nCIUnoohxed0PR01jHKgPKO78cTL7kE8Kbi5i7N9tNZahsR4axJkJbkyr6gG8HRR0R5VnnUL4tycyhkBb1-Aa07CGp4a-HZdTwPCX-6Z92UbylB61zO2C_O4ymgySJEv91e-o6UDmDiB_y-Izb_K393omzYMmwfgh08J9sOWoMYKZBxrUftDpJpt1Cuq7poI7mWp7eEBcFUI37JQgJXC7UtNH7Q-SzMX0K_47MY0acrErRul88VKAq7oDH2qcS67itqpe2Nb2WIuGw3DTzBXU0GwtPAAImBu_KIj0BULr54M_DUZV0h60oKIidnpUtIJbxIhFlijd65q9uUK33EcBlWTZgDNeFwYQ_TRs4ShuGtMHAy2gxbA=w1407-h1057-no
34 Tact
New Mexico
Good morning all, has anyone used this product with a retrax bed cover. I apologize if this has already been addressed.
OffRoader01
USA
Yes I am using it with the Retrax Pro MX. Only issue is the space lost at the front of the bed by the cab. If you install the front two racks, you will need to uninstall the cover to get them in then reinstall it. But otherwise works great.
93,202
56,485
bjorn-dpc
