Forscan changes - tweak your truck
WV Dual Sport
West Virginia
Guys question on DRL
I changed my 2018 to run the DRL- parking lights only , stock LEDs.
I currently have my settings (I think) at:
726-26-02: x1xx x1xx x1xx
726-50-01: 01xx
I would like to run parking lights and the low beams. I input the following :
726-26-02: x1xx xxxi xxxi
726-50-01: 02xx
I get an error message when trying to input the parking lights and low beams...
What am I doing wrong?
My wife thinks I only have 3 guns
At 726-26-02 I have 0100 0000 0056
What do you have at 726-26-01 ?
EDIT: I just sorted this out for myself. It may not apply to you, but it could....and it may help others.
I was trying to program the truck to run DRL's on all the orange lights, Markers, Halo, and Turn signals. EVERY TIME I programmed the BCM module, nothing seemed to work. I kept getting the park lights AND the low beam lights on...just like before. I reflashed the backup and tried again.....same results. I gave up, backed the truck OUT OF THE GARAGE and went around the block to see if the seat belt minder, etc., had actually worked. They did. AND the DRL's were working too. The lighting in my garage was not enough for the truck to function as I had programmed it and it was running as if it were dark while in gear, with the brake set (while checking it). Doh! The dash sensor needed more light for the system to actually work as intended (and correctly programmed). -_-
Gunnut
Cut Off, LA
Any one know how to get the doors to unlock once I place the truck in park?
And yes, for all the internet ninjas, I can hit the unlock button, but in America I don't have to... so I would like to unlock my doors when I put the truck in park
My truck did this from the day I go it. Must be in the trucks settings. Not a forscan thing.
GCATX
King Dingaling
Central Texas
This drove me crazy. I ended up just turning off the auto lock. Can't remember if it was with forscan or dash settings.
Derail
From the manual. Doors and Locks section. This is selectable in the instrument cluster.
Autolock
Autolock locks all the doors when:
  • All doors are closed.
  • The ignition is on.
  • You shift into any gear putting your vehicle in motion.
  • Your vehicle reaches a speed greater than 12 mph (20 km/h).
Autolock repeats when:
  • You open then close any door while the ignition is on and your vehicle speed is 9 mph (15 km/h) or lower.
Autounlock
Autounlock unlocks all the doors when:
  • Your vehicle comes to a stop and you switch the ignition off or to the accessory position.
  • You open the driver door within 10 minutes of switching the ignition off or to accessory.
Note: The doors do not autounlock if you electronically lock your vehicle after you switch the ignition off and before you open the driver door.
Livnitup
SoCal
The truck won't unlock the doors by simply putting it in Park with the engine running like dropping the kids off at school and we haven't found anything in FORScan to achieve this.
93,202
56,485
bjorn-dpc
