GEN 2 R1 bbk
trophycummins
Simi Valley, CA
Oem brake lines are m10x1.5
Every ford after 2015 does this. When the fitting tightens down, the flare of the line deforms the bottom of the factory fitting.
We use a thread file and a die to clean up the threads before installing the new lines.
brettmess24
brettmess24
That would be why I can’t find any!
Do you know if it’s 1/4” or 3/16” line?
OPT PRIME
Six piston rear calipers! Although I don’t understand unless it was to maintain the front to rear fluid and bias ratios.
FmaxTurboSi
So Cal
Thank you sir!!!!! Ordered eight of them.
It’s definitely the factory bolts and not the R1 braided lines. I finished up the passenger rear and the bolt was delicate but I got it!
any more progress???
