ARE DEAVER LEAF SPRINGS worth it ?
Nick@Apollo-Optics
Thank you all so much for ya input do you suggest I go the +3 if I’m going to run 37s??
From what I have read the +3 should be no stiffer witch is hard to comprehend as there are more leafs.
Thanks again
If you're going to be running 37s, the extra 1" of height over stock will definitely help.
warrior
Your Wife's Personal Trainer
since you delete the the blocks, do you have to run the bump stop? No whoop running for me.
Deleted member 12951
If you do not get a full bump stop kit, at the very least replace what was there from stock. SDHQ sells a bump stop mount plate that accomplishes this
Lwlandy
I fitted Deaver +2" this weekend to my 2018. The truck is a lot more sure footed on the black stuff now. (Yet to get it off road). There are some bad roads round where I live and I was getting the rear end step out on me a lot on bumpy tight bends. Its only been a couple of days, but it is night and day. I have driven over the same bad roads and not felt a thing. It also now feels a lot tighter on the road powering round a flat bend. Pleased I decided to fit them.
Jeff-Ohio
Cincinnati
How does the firmness of the ride compare to stock? Is it softer, firmer, about the same?
HAP
NE NC
One of the most satisfying MOD's you can do, besides super charger...
R,
HAP
Lwlandy
I think they are as per the nature of progressive springs, softer initially (so they absorb the small bumps easily) but then get firmer the further they get compressed. Makes for a nice compliant ride on tarmac but more capable offroad when under more extreme compression.
---------- Post added at 11:17 AM ---------- Previous post was at 11:12 AM ----------
what are you guys seeing in terms of labor costs to install these?
I fitted them myself, took me all day Saturday (I also fitted SVC Bump stops). I was on my own and the springs are heavy. It would be better with 2 people as trying to get the springs in place without damaging anything like Brake lines road speed sensor etc. is not easy on your own.
I would say that a decent shop with the right equipment should be able to do it in 3-4 hours.
Skyline
no issues with leaf spring bolts right? Old gens you had to cut one of the leaf bolts out because of the way it was oriented. I havent looked at these.
93,171
56,440
jumpcutter
