Forscan changes - tweak your truck
shelteredraptor
on a rock
well that isn't exactly brilliant. I can't imagine they wouldn't give the ability to return the truck to the stock tune? Every one I've ever had retained a stock file.
xxaarraa
Southlake, TX
Gents, I too have a question about TPMS but not how to retrain it. I run 30 psi all around in the winter (new england snow and ice) and every time I start the car it throws a low tire pressure warning.
Is there a way to re-baseline the acceptable tire pressure values via forscan so that it doesn't throw an error each startup?
Hello, does anyone know if there is a solution to this question?
ogdobber
Yes. But you don't retrain the tpms, you put in forscan the pressure you want to run
Livnitup
SoCal
Yeah, how?
BCM
726-40-01 xxxx **xx xxxx TPMS Placard Front Tire Pressure (convert p.s.i. to hex)
726-40-01 xxxx xx** xxxx TPMS Placard Rear Tire Pressure (convert p.s.i. to hex)
Examples:
726-40-01 xxxx 1E1E xxxx - 30 psi front & back
726-40-01 xxxx 2323 xxxx - 35 psi front & back
xxaarraa
Southlake, TX
it’s on like page 1 or something. Repost of the relevant links.
https://docs.google.com/spreadsheet...iVSlDFGFHnfeuhb3RTMVz95730/edit#gid=815852466
https://docs.google.com/document/d/1-8dKaS_Spu4Zw4hV_CrKC4tLoP9G8yejqegF1wxIqxY/edit
Just to clarify, lowering the TPMS values is just a workaround. The solution is to
MOVE SOMEWHERE WARMER, WHERE HUMANS WERE INTENDED TO LIVE !
:p
I checked on that spreadsheet. Does not have anything related to 726-40 like Liv posted below.
BCM
Examples:
Thank you Liv, appreciate it.
I could have sworn that was in the spreadsheet, it was one of the ones I was going to do and bagged it. now you’ve got me wondering...
you still need to move some place inhabitable by humans tho.
