Second update on engine disintegration
EricM
OHIO
So what the hell is up with the camshaft being a multiple piece splined setup? Is there some advantage to that design? There's obviously a major disadvantage to that design.
t_j
Chicago, IL
Probably allows them to use the same components in more than one engine, by adjusting the angles at the splined joints. So cost savings.
SilverBolt
Hired Gun
Portland, OR & Eureka, MT
Likely has something to do with the hollow cams. It would be very time consuming and difficult to bore a hole the full length of the cam and keep it true and precise. Done as two shorter pieces it would be much faster and easier to keep true.
Monsoon Chopper
Phoenix, AZ
As mentioned before, one of the exhaust cams broke. Interestingly, these cams are put together in more than one piece with splined inserts and the splines wore down and so part of the cam was not turning. So of course valves were hanging down banging on the pistons so all three pistons on that side, plus rods and the complete head assembly need to be replaced. Also, unburned fuel made its way to the catalytic converter and destroyed that as well.
Ford is not willing to replace the engine but has instructed the dealer to make the repairs. Obviously this does not sit well with me and so I've opened up a case with Ford customer care… more to come......
Who are you talking to at Ford that is saying NO? I would be asking to speak to their boss, until you get the SVP of Customer Support. I've done this on some powersports and not only did they replace it, they gave me the next year model when they totally revamped it.
You have to be your own litigator here. I would either ask for a new motor or new truck, in fact I would ask for a new truck. Using the case "if you can't get the motor right, what else could be wrong with this particular truck?"
You did not buy the truck to give the local dealer techs hands on training.
93,411
56,694
forcefed23
