DIY - Stock Raptor 2.5 Shock Rebuild.
mmaterni
Toledo Ohio
First time
Hi,
Sorry if this was covered but I have been over the PDF's and thread and couldn't find it.
What is the torque spec for the nut on the piston?
Also, I have never used the equipment to refill the nitrogen but will be purchasing everything to do the rebuild soon. How does this equipment work? I understand the use of a regulator and that the needle injects the nitro to the shock but what are the Rubber Pellets for?
Hopefully there will be a video soon or maybe I will document my first time rebuild so others can learn from what I screw up. This is a great write up and I really appreciate all the work thats been done here. The FRF crew is awesome. Thanks for any help.
m3dragon
m3dragon
Orangevale
Hi,
For the nut, tighten down 1/8 turn after tight. On average it is flush to the bace of the shaft.
The regulator sets the pressure so you won't go above the 240-250 psi.
If you need direct help, shoot me a PM and I will give you my cell. I have helped several members remote via text or whats-up out of country.
mmaterni
Toledo Ohio
PM sent. How is everyone getting the bottom shock bolt tight to spec? I have seen torque multipliers, impacts, and bars all mentioned.
m3dragon
m3dragon
Orangevale
You mean when you install. It should be 300lb tq.
Get a 700lb impact from harbor freight for 60 bucks. Job done LOL.
PM replied
mmaterni
Toledo Ohio
Does anyone have a part number for both of these items?
- New front or rear screw cap (What Fox calls the cap that holds the bleeder screws and seals) $35
---------- Post added at 09:43 AM ---------- Previous post was at 09:25 AM ----------
Ordering everything I need to do rebuild this week. If anyone has tool sets they no longer need or want let me know and I will buy them used rather than new.
Need:
Spanner wrench
Guage and valve
Tank
Snap ring pliers
And all needed bolts to disassemble reassemble shocks.
Have everything else.
t_j
Chicago, IL
Spanner wrench can be made quiet easily with a couple of pins and a length of bar, a drill a grinder and a welder.
Plenty of options on fill kits online do some searching I used raceready products for mine.
Tank - go to your local beverage supply house and buy a used tank there should be less than 100 for a small tank.
MTUH3
Plymouth, MI
I went to my local airgas to get a tank and gauge. I stopped by a local transmission and hose shop and they made me a custom length hose, will all the needed fittings, for under $30.
Everything else I ordered from the OPs list, shock parts I got from SDHQ
mmaterni
Toledo Ohio
Went to my local airgas supplier today as well for the tank and gauge. Ordered Seals, new shock fluid, fill adapter and spanner wrench from OP. I have plenty of hose and fittings here so I'll make something work. Planning on writing up how it goes after I git r done.
jef
belgium
1. Bearing Housing Front 203-00-024
2. Bearing Housing Rear 203-00-026
3. Rubber Pellet 010-00-000-a
4. Screw 010-00-017-a
5. Ball 010-01-000-A
Staff online
93,423
56,706
marquez47
