Wheel Fitment issues
Discussion in 'Ford Raptor Exterior Forum [GEN 2]' started by maddrama, Apr 4, 2020.
  1. Droid
    Droid kglesq's Brother
    1,162
    287
    Sep 25, 2010
    Take a look at this: https://www.1010tires.com/Tools/Wheel-Offset-Calculator#
    Stock wheels are 8.5" width and 34mm offset. Your wheels are 12.5" width and -44mm offset. You're pushing the wheel out 129mm, or a bit over 5" (each side). That's just way outside the acceptable geometry for the fenders. Also, it's going to multiply the torque going through the A-arms and rear axle..a given force on the tire will compress the spring notably further.
    Bear in mind these things have 13 (front) and 14 (rear) inches of suspension travel. And the bypass shocks are setup to let you use that travel all the time for control, it's not just there for big hits. If you even lightly offroad, or visit an uneven starbucks parking lot, those wheels will remove your fenders.
    if you fully articulate the rear, the compressed side tire will actually tuck into the fender (the rear actually will travel much farther than 14" if the axle is articulated).
    Pic is from this video (not my truck):
    PS the video only shows how far the rear end travels...the front is using next to no travel as it has a sway bar...it'll use all its travel on impacts though.
Share This Page
