Whats the easiest way to access the Gen3 Horns?
Renomaan
I installed a dual compressor Train horn (which I had on my 018 Gen2) and I need to get to the Gen3 Horn,s so I can pull a trigger wire off one of them.
The hot from the existing horn will throw a relay to turn on the airhorn compressors, so the OEM horns sound with the airhorns at the same time.
What do I need to take off to get to the horn wires?
shroud?
Panels?
from topside or thru grill side?
Just trying to save some frustration and time
thx
R
Renomaan
The rubber top mat rolls out of the way after the push rivets are out of the left side.
I then used a multi tool with wood blade to take out a pc of plastic that won’t be seen once the mat is back in place.
The horn connector then pulled off so I could get a lead to trip my relay
R
Renomaan
I e got Forscan loaded on my pc and I’ve got the obd adaptor, just gotta dig in on it yet
