what is "normal" coolant temp on a gen 2
Discussion in 'Ford F-150 Raptor General Discussions [GEN 2]' started by goblues38, Feb 16, 2019.
  1. goblues38
    goblues38 Full Access Member
    909
    761
    Oct 27, 2018
    STL
    I have the coolant temp enabled via forscan, 212 is pretty much where my truck sits with normal driving.
    just curious as to what "normal" for this truck is, and what kind of temps does everyone see in the summer or under heavy loads.
  2. 2xtreme
    2xtreme Member
    5
    Nov 12, 2018
    Hampton Roads Va
    I'm wondering the same thing.
  3. image98
    image98 Full Access Member
    54
    45
    Sep 18, 2017
    California
    Based on my observations, 205-215 degrees fahrenheit is a normal engine coolant reeding range depending up driving factors. The transmission appears to be happy around 180-185.
  4. Loufish
    Loufish Full Access Member
    60
    904
    479
    Dec 30, 2017
    Burbank CA
    My coolant temps seem to range between 205-215...a little warmer then I'd like to see, but many others see the same temps...
    Trans temps are also warmer then I'd like to see 190-195...
  5. Trick.Raptor
    Trick.Raptor The Cracker Raptor Supporting Member
    3,920
    7,539
    Nov 7, 2014
    Santa Maria, CA
    The Gen2 runs hotter than a Gen1 it appears. There shouldn't be an issue with that as long as there is enough cooling capacity to keep the everything cool when pushed hard.
    With the Gen1 I am pretty consistent at 194° on the highway and rarely see anything over 214° in traffic without the A/C. With the A/C on in traffic it sits around 194°
    Pushed hard off-road with high speeds and high RPM I see 225° a lot!
    I'm curious to what the Gen2 does when both turbos are at full boil and the engine is being pushed hard. Anyone see/know what those temps are?
  6. Loufish
    60
    904
    479
    Dec 30, 2017
    Burbank CA
    Out in the Mojave desert last summer with temps around 105+ and the truck ran about 215 all day and that's including a fair amount of just idling....and yes the AC was on the whole time...
    Trick.Raptor likes this.
  7. ace75
    ace75 Full Access Member
    95
    18
    Oct 3, 2011
    Towing up the grapevine, I saw about 234 degrees. The trailer weight was around 7000lbs. Ambient temperature was around 80-90. I slowed the speeds down when I saw the temperature hit 230’s. Not sure what the norm is. I’d like to hear if anyone’s upgraded to the full race radiator and seen improvements in cooling over the stock radiator.
  8. nikhsub1
    nikhsub1 FRF Addict
    1,013
    535
    Mar 5, 2017
    with a 170 thermostat i never see above 195. normal is 180 ish.
    Wfo likes this.
  9. Wfo
    Wfo FRF Addict
    1,516
    1,005
    Sep 22, 2013
    Syracuse
    I have the full race radiator and larger transmission cooler, also have SVC front mount. I see 205 and sometimes 215. The larger rad won’t lower temps, just more capacity so temps should be more consistent. I’m considering installing a lower temp thermostat, only concern is how long it will take to warm up in the 0deg winter months.
  10. nikhsub1
    nikhsub1 FRF Addict
    1,013
    535
    Mar 5, 2017
    It will warm up just as fast no matter what thermostat you have - it just won't reach as high of a temp. In cool/colder weather my temps hover around the low 170's - you should expect that as well even in zero degree weather.
    Trick.Raptor and Wfo like this.
Share This Page
