GEN 2 Up fitter switches not powered?
Kinger9
Trying to tap into Aux 6 on my 19 and the damn wire is not hot? I have both bundles and I’m tapped into the one closest to the distribution block. No power when on or running. Fuse is 5am and looks good.
What am I missing?
Kinger9
Kinger9
Oh geeze! That’s it! Wtf the manual clearly says those are pass through. Thank you so much!
For any future searchers:
These are closest to distribution box but are NOT powered.
The ones under the PCM ARE powered!
Exactly opposite of the manual:
Jace21583
That was only for the 17 and they never fixed the manual. Glad you got it figured out...I ran into the same issue way back when.
Lightning4570
Michigan
Field service bulletin 18L06 corrects the diagram to the Raptor supplement. I only discovered this by logging into the notifications I got via the My Ford Pass app.
Jeff
Rapster
Dallas, TX
I just installed fog lights on my 18 and same thing, it’s the bundle closest to the engine. Also if you look closely at the wire sizing, you’ll note that two wires are thicker (15a fuse) two are mid sized (10a fuse) and the two smallest wires are the 5a fuse (upfitter switches 5&6 I believe).
