Truck not starting
R
Raptor92
Not sure if this helps, but at 6,000 miles my truck nuked the starter.
View attachment 165093 View attachment 165094
Sorry to hear that,
since it might be it too in my situation
Because I have performed all the recommended tests by jump starting / disconnecting the terminals overnight...etc with no luck.
Will have to tow to the dealership and give it a shot.
And update back on the forum
Thank you everyone for the valuable assistance
R
Raptor92
Fortunately got the issue solved
It was not a battery/cables/starter problem
I've replaced the power relay in bjb and everything came back to life, no more errors and fired right up.
Connected Diagnostic tool and no more codes.
Everyone's input was helpful, Thanks
R
Raptor92
Might want to carry an extra one around with you incase it happens again. Something caused the relay to go, they don’t typically just blow for no good reason.
Yes will surely do so
It is weird indeed, because I haven’t performed any electric services or added accessories or any kind of work.
The only thing I usually do is place the truck on a CTek charger, it might be it.
