Man, that much huh? I guess they are pretty heavy to ship...I'm looking for a set for kind of an experiment to get me by until I can afford to pony up for a set of Nationals or Deavers. I recently installed a RPG stage 2 kit on my truck (which blew my budget for a while), and with the stock springs you need to run longer impact pads on the air bumps. Well with those installed i have so little up travel I smack the bumpstops all the time coming in and out of my driveway and whatnot, and especially when I have anything in the bed. So I did some measuring to try and figure out exactly why you needed that extended pad with the stock leaf springs and not with aftermarket ones. It looked to me like the reason you would need to limit the up travel is because the stock springs would smack the RPG brace at full compression, with the stock bumpstop pad on the axle smacking the frame like .5" later. So I figured what I could do is add a leaf to my existing pack, then remove the stock leaf block and replace it with a stock F150 block or something even shorter. This would (hopefully) net me the same ride height as stock but have the top of the spring pack be about 1.5" lower and the bumpstop pad gone. That way I could run the shorter pads on the air bumps but not have to worry about damaging anything at full compression. So I started researching what add-a-leaf to buy, and everyone was talking about the replacement leaf being thicker than the stock leaves or having a way different arch or whatnot. So it occurred to me that I should be able to buy a factory leaf pack, take it apart, and with a bit of doing use one of the stock leaves as sort of a factory add-a-leaf. It would be the same width, I could cut it to whatever length I needed (within reason, obviously), and it would be the exact same arch and spring rate as the rest of the pack. I figured if I could do that for a couple hundred bucks or less it would be worth it, and it would buy me a few months until I can get a whole new leaf pack. Thats what i was thinking, anyway. Am I crazy?
