Steering off-center after offroading
Discussion in 'Off-Roading Your Raptor' started by kevin85, Oct 17, 2017.
  1. kevin85
    kevin85 Full Access Member
    78
    42
    Nov 10, 2015
    CA
    Hi all, so I took the raptor offroading and got some air time. I noticed now that when the truck is going straight, the steering wheel is off to the right a little bit. I just got the truck aligned not long ago, is this an alignment issue? or could be something else. I took a look at spindles, LCA, Tie-rods, nothing seems to be bent or damaged. Thanks
  2. AndysLog
    AndysLog FRF Addict
    1,114
    506
    Jan 12, 2017
    Moro IL
    offroading loves to eat alignments. if you can find a shop that has a 6month alignment agreement. take it back after every adventure.
    kevin85 likes this.
  3. SZDZMTR
    SZDZMTR FRF Supporting Member Supporting Member
    2,101
    1,593
    Sep 19, 2016
    Sewell, NJ
    ^^^^ what he said. Just play dumb when you go back. lol
    kevin85 likes this.
  4. Aaron
    Aaron Meme Corps Commandant
    35
    13,164
    7,457
    Jun 13, 2011
    Tucson,AZ
    This was simply your truck calibrating itself to the offroad terrain. If the steering wheel wants to hang to the right, who are you to tell it that it should straighten up?
    Micha, Jimbob, FarFromStock and 4 others like this.
  5. kevin85
    78
    42
    Nov 10, 2015
    CA
    thanks guys, maybe I should get the firestone lifetime alignment
  6. MatMan
    MatMan Full Access Member
    890
    437
    Jun 7, 2012
    AridZona
    Also recommend the SDhQ alignment cams, which cam in place to eliminate or reduce any movement in the alignment settings.
    kevin85 likes this.
  7. dude1782
    dude1782 FRF Addict
    1,327
    1,108
    Sep 2, 2016
    PHX, AZ/SLO, CA
    Something in my power steering is broken somewhere. I have to take it in so they can figure out what's wrong and fix it. I put on a lot of off road miles and took it in to get an alignment and after they got it aligned and driving straight, the steering wheel was pointing right. However, I did get under it and look around and didn't see any damage.
  8. Raven13
    Raven13 FRF Addict
    2,194
    2,997
    Sep 30, 2014
    College Station, TX
    After Raptoberfest my steering wheel calibrated itself to the left, part of off-roading!
    kevin85 likes this.
  9. MatMan
    890
    437
    Jun 7, 2012
    AridZona
    I had an off center steering wheel after alignment once and simply took it back for them to adjust, took them 10 min.
    That alignment shop just could not get it right due to lack of the right alignment technology. So I took it to the dealer and for $160 they nailed the alignment and it's been good ever since. My point is, it may just be a simple adjustment. Try Ford if you haven't already.
    kevin85 likes this.
  10. AndysLog
    AndysLog FRF Addict
    1,114
    506
    Jan 12, 2017
    Moro IL
    These lock your bottom in correct? How do you adjust if it’s locked in place ? Curious if you don’t have aftermarket uppers you are basically just raw dogging it
Share This Page
