Rock Light Mounting Locations and other details
caisaacson
Tennessee
Who has some pictures of:
Rock light mounting locations (front and rear)
Rock light control module mounting location
Now the only other thing I need some ideas on is chasing 8 wires though the cab to the module.
Thanks in advance everyone.
The Car Stereo Company
aka grumpy car stereo guy
here, on frf
i used 24v led strips with a step up converter. as well as other white led strips to illuminate the entire underside of my truck. i went this route, because i did not want to have anything bulky like pods on the underside that could get torn off easily.
here, on frf
i will get pics soon. they are what i call functional underside lighting. i can pretty much work under my truck at night without any other lighting if needed. also my wheel wells are lit up, as well as in front of my front tire and behind my rear tire
here, on frf
this was taken at night with no other lights except my underside lights. once you pull the wheel off, the entire wheel well is lit up so changing a shock or axle or whatever, is easier since you are not dealing with holding a flashlight. the under side lights are actually bright enough, they reflect off the ground and light up the whole area underneath........ and to keep with my theme, they are also in rgb..... haha
here, on frf
a closer shot of under my truck. these are just the underside lights and not my wheel well lights
Java
MI
I used aux 3 and ran the lines in loom thru the frame 6 lights "off road only" brand they have a magnet in base that works well and I could move them to try different locations. There is a hole for screw fixation. Settled for one front bumper forward, one under trailer hitch, and 2 on each side. Mine are red because I mostly use them loading and unloading for fishing and hunting. They light up the area so I can make sure I haven't dropped anything.
justcozz
Madison, AL
Can you (Noah) get a pic of the actual lights to see the mounting locations? That setup looks awesome!
