Redo SE Beauty rings
  • Start date
Guest
Off-roading and getting into deep ruts have pretty much ruined my rings (plus hitting a wall, oops). I am debating about trying three different ideas and wondering what others thought?
1. Find SE color code and have them sand blasted and powder coating again. Still want to retain the red SVT.
2. Same as 1 but powder coat them black to match the wheels.
3. Same as 1 but have them Line-x black or SE color if possible. Leaning towards this option to be more durable for future runs.
Has anyone ever Line-x beadlock beauty rings? Anyone know the SE ring color code?
OrangeAddict
Raleigh, NC
Do you have any deep gouges in the metal or all of the marks only paint deep? If so what is the plan to deal with the gouges? Just curious, cause I need to do something with mine when I put the headlock rings on.
Guest
You got a point, yeah deep gouges. I was figuring they won't be so noticeable if painted or line-x. Right now they are because the metal is showing.
OrangeAddict
Raleigh, NC
I would worry about the linex messing flat mounting surface so I would at least tape that back part off. For mine I am not sure you could just paint over them, I will send some pics in a bit. I might be able to sand them down to where they are smoother and less noticeable unless your looking. I just think the price for the beauty ring itself is a bit much. hoping to find a good take off set from someone wanting to change rims.
Guest
Here are some pics, two are worse. Plus I already switched out the spare for its ring so my current spare is about as bad.
The Car Stereo Company
aka grumpy car stereo guy
here, on frf
its just a rim. but maybe you could have 2 sets. anoter member is selling his se beadlock rims. keep these as your offroad set, and keep the new ones as your street queen set.
ALDABRAMAN
SW Florida, USA
I have seen them powder coated black and they look fantastic. The concept of line-x is also appealing to me, that would be neat!
squeak
Would you need to have the wheels balanced again after you do this?
OrangeAddict
Raleigh, NC
I usually have mine balanced when I get my alignment checked and tires rotated every 5000 miles or so.
Here are mine after close encounters on several offroad trips. I did not take pics of the 2 spares.
oxfordraptor
They're just trim rings I wouldn't worry about it. It will most likely happen every time you go hard off road so why fix it? Either buy a set of wheels to beat on and keep a good set or just move on. Waste of money for other solutions IMO. Mine are eaten up too after off roading and crawling BTW.
