Rear leaf upgrade ?
NCBen
Holly Ridge Nc
Are new and/or bump stop kits required if you go with Deaver for example? Thanks
QCRappy
Charlotte, NC
I sent you a text. I have icon's installed and used their bump stop spacer with the factory bump
M_NorthRaptor
British Columbia, Canada
Not 100% needed unless you offroad hard. I installed icons and rpg bumps and did some moderate off roading and used half the fox bump stop with 85lb of psi in them . Heard of guys smashing the oem bumps and messing that part of the frame up with the spacer. spending the extra 2g is a bit but will save your rear end greatly having them and your back.
If I was you I would purchase a bump kit as well
NCBen
NCBen
Holly Ridge Nc
Thanks for the heads up. probably wont be offroading "hard" and probably go with the +2 equivalent on the spring options. Will look into the kits but fk me they are expensive ish.
pbtjrlmrt
Oregon
Leaf spring upgrades and bump stop upgrades are two completely different things. One does not necessitate the other.
Based on your question I'd suggest contacting Deaver or Icon directly and speak to their tech about what you are trying to accomplish. Take their guidance over people on this forum.
NCBen
NCBen
Holly Ridge Nc
understood yes the ask fundamentally does swapping out springs with add the necessity of a revised bump stop situation. Or can brackets be flipped around etc etc and use the stock bump stomps. it is also understood that the stock ones even with stock springs are suspect for HEAVY offroading aka send its.
