GEN 2 Random low tire warning
Johnfaeglasgow
Kansas
Got a low tire warning yesterday but don’t know why... They are all pretty low in the morning when it’s cold, but I thought the warning would go away when driving when they warm up. Bad tpms sensor? 19 with 5,000 miles.
wheelman55
Big Bend or MN
I had one sensor go bad on my 2018 Raptor. The dealer replaced it under warranty. This TPMS would intermittently read nothing though.
Try doing a few things.
  • Check the actual air pressure with a pressure gauge on all tires. Compare what the gauge reads to the values on the dash. Choose one.
  • Air the tire down on the misbehaving corner, say to 28. Drive around for a few miles. See what the display says. 28 psi should give you the orange color with a dashed line instead of a psi value.
  • Air the tire back up to what you want the pressure to be. I recommend 34 psi for the rear tires. See what the display says now.
  • While you are at it...air the front tires up 4 psi above the rear tires. I like cold psi of 38 front/34 rear for highway. Just keep that 4 psi delta front to rear. If you are airing up the tires when they are warm, bump the psi up 2 psi to 40 front/36 rear.
Let us know how this works.
Best.
jzweedyk
Moab/Winter Travel/Summer Travel
Sometimes after airing down, when I air back up the low pressure light will be on but the pressures show the correct amount. By the next day it is fine. I think it has a mind of it's own.
aka grumpy car stereo guy
the door states cold tire pressure. if your pressure is at the recommended psi when its hot, then you can be off by 8-10 psi. when i go play in the sand im down to 20psi and when i fill them up again when im done, i always go to 50 psi (1st gen recommended is 44psi cold) and when i check them in the morning, they are sometimes still below 44psi. they give you the cold psi because depending on how you drive, additional pressure from heat varies so a standard is for cold tire pressure.
J
Johnfaeglasgow
Kansas
I parked the truck inside all day and reset the pressures to 38/34 and drove it a couple hundred miles. The warning finally turned off after its third stop/start. Weird, but it’s all good now [emoji2371]
Thanks guys
