Please Help Me Decide Between 17s and 20s
galan.kelley
I’d personally stay with the 17’s. In my past experience, I’ve have 37’s on 22’s and 35’s on 20’s. I can honestly say, you will be giving up quiet a bit of comfort and performance. I’d stick with the 17’s or even an 18 wouldn’t be bad, but any bigger will decrease your performance. I changed the 22’s down to 18’s and it made a huge difference in the ride quality. Also, make sure your going with a reputable shop to install the C.A.S., I have the same set up and I’m not a big fan. The ride is extremely stiff, especially if you set the threads at the 1 9/16” (per the directions, if my memory serves me right) and you have to bleed off the nitrogen and install a schrader valve to refill. I tried the 200 psi like the instructions called for, but had to take it down to 150 psi and lowered the collar some to get a better ride. I say this not to discourage you, just sharing my experience based on my preferences and I typically drive 80k - 100k miles per year with at least 40% of those miles off road for my day job.
torrin
Nashville, TN
The one big advantage for 20's is you can use brembos and other high end calipers. The 17s are a bit too restrictive. For mostly offroad, 17s are the best.
raptorwarrior
I had the same crisis as you a couple of months ago. I went with the 17s. They look absolutely awesome in person.
soulsea
soulsea
SC/AZ
I honestly much prefer the look of 20s.
But I went it’s the 17s because I’m not trying to impress javelinas and mountain lions. :smile:
93,319
56,605
Randigitty
