Plastic pulley on Motorcraft belt tensioner? Damn!
vegascarnut
Henderson, NV
Ordered a new one, got it and the damn pulley is plastic. Disappointing to say the least. I'm sure it will be fine, but the original has the metal pulley, which is also a little wider. Tried the old pulley and the bearings won't fit the new shaft—machined differently. Guess the old part becomes a spare. Grrr. Just venting.
tltoronto
toronto ontario canada
Does the plastic pulley have recessed edges to help keep the belt straight? I have not yet had to do a tensioner, (thankfully) but on previous vehiles, I was able to press the old bearing out of the tensioner and replace it. Can we do that to the original tensioner?
vegascarnut
vegascarnut
Henderson, NV
No, it's smooth, just like the original pulley. You can press out the bearings and replace, but that doesn't replace your tensioner spring, which fails as often as the pulley itself. They just get weak and stop doing their job.
JohnyPython
Canada
Wife’s Jokeswagen has composite pulleys. They’re fine. VW “composite” water pump impeller, that’s another story.
