Oscar_14
Good day everyone.
Wanted to discuss a problem with the F-150 Raptor 2017, 3500 engine. Hopefully someone can help or recommend something.
So basically the problem is the noise coming from the front axle, specifically from the wheel hub. The noise sounds like scraping or scratching. When both axles are being used, noise is not present. But if only the rear axle is used, then noise starts coming out from the front axle, and mostly at 1500 rpm.
To the date the hubs, gearbox and transmission gear case have been changed, but the noise did not disappear. Right now the suspected reason for that noise is solenoid-operated valves that transfer the air and pulls the wheel hubs. They might not be working properly. But at the moment we don't have any spare valves for the replacement.
Below is the google drive link with the pictures and videos of the wheel hub.
https://drive.google.com/drive/folders/1x1OmCHv6Mv68Mk1Rs6ooLcKdGHIKsGGM?usp=sharing
Hope someone is familiar with the problem, since there is no Ford service centre here in Kazakhstan.
Thank you for your attention.
