My Doug's Cut Out Install
HAP
NE NC
Just wanted to share my cut out install and an product opinion. Why Doug's? The all SS design, unobstructed flow when open and gate style valve is why I went with Doug's. However, the Y cutout is the big disappointment for me. I knew this up front and ordered a SS Y cutout from Pypes. Now that is what should have come in the kit. I would have been happy to pay $50.00 extra for that quality. The only disadvantage is the one I ordered required welding on one end vs slip-on. This was no problem and I was able to orient the Y exactly where I wanted it before I welded it. I decided cut the stock clamp end off of the resonator pipe and reattach it to the Y pipe, that way I retained the factory safety lock design. BTW, Ford will not sell the factory clamp as it is tack welded to the resonator pipe.
I really studied where I wanted the wires to enter the cab. I found that the shortest and least intrusive way for me was right up to the center console where I planned to mount the switch. I just tied into the rear 12V outlet for power and ground. The in-line 5 amp fuse should be enough protection. I simply de-pinned the motor connector and fed the wires from the console through the 7/16" hole I drilled with a tight fitting grommet back to the motor. The rod in the pic shows the angle to intercept the existing hole above the drive shaft. To reduce water intrusion I packed the motor connector with dielectric grease.
I have to say though, I did not like tearing into the interior, and did so more than I really needed to. But I wanted to make sure I my strategy covered.
2014RubyRed
Galesburg, IL
I wanna do this. Is there anyway you could take some more pics of the cutout installed? I'm trying to figure out the install points, and need to see a few more under the truck. I appreciate it!!!
Marcsc1
Alden, NY
I've had the Dougs cutout with the turndown installed for 18+ months, placed it right after the resonator. The sound is incredible and would definitely reccomend.
Definitley agree with the OP on the Y pipe offered by Dougs, complete garage but beyond that top notch on the cutout and wiring.
HAP
HAP
NE NC
"ordered a SS Y cutout from Pypes"
Do you have the part numbers?
Is it Y EXHAUST CUTOUT 3" 304SS YVX13S ?
Thanks
Yep that's the one.
Pypes Performance Exhaust YVX13S - Pypes 3 Y CUTOUT 304 stainless
R,
HAP
---------- Post added at 06:50 PM ---------- Previous post was at 06:46 PM ----------
look's good do you plan to put a turn down on it?
No turn down planed. I think it might be annoying when starting the engine on beach and blow sand everywhere. Plus I like being able to look right into the valve when needed.
R,
HAP
HAP
HAP
NE NC
So, any chance for some additional pics?
For Crown. Let me know if these give you what you are looking for.
For my install I cut out 8, 9/16" from the resonator pipe. You can see I cut the clamp off at the termination of the major diameter. Then I cut the 8, 9/16" off of the remaining resonator pipe for the overall length. Nothing was cut from the muffler side to retain the turn-lock feature. You cant see it any of my pics, but it is a little stud that fits in a keyway that you turn to lock/release the resonator pipe.
2014RubyRed
Galesburg, IL
That's perfect!!! I really appreciate it, @HAP!!!
I've got the Dirty Deeds and have already removed my resonator, so hopefully this will be a little easier for me.......
tahitiansoul
Tahiti
Love the cutout, one question: what model and brand of traction bar do you have there? Thanks
