ayoustin
- Joined
- Jul 31, 2018
- Posts
- 162
- Reaction score
- 253
Bulletproof? As a service technician, that is a comical statement. The Ridgeline is a FWD minivan-based joke that overheats with mild off road use. Toyota can't keep a frame under their cheaply built "trucks", which includes Taco, 4Runner, and Tundra. As far as Tundra, would you like me to elaborate on the AIP failures, cam tower oil leaks, rusted out differential housings, steering gear failures, sticking brake caliper pistons, bed to body contact issues, and 3UR-FE (5.7) valve drop issues? That's just the most common ones, there are plenty more to discuss. It's amazing how these companies can so easily con the average consumer into buying into their BS. I would have loved for someone to walk into my service bay as I have the heads off of a Toyota and exclaim "what are you doing? It's supposed to be bulletproof!"
Here's the frame rust lawsuit info. The newer models have the same issues, nothing changed.
https://www.autoweek.com/news/a1857861/toyota-will-settle-truck-frame-rust-suit-suit-34-billion/
I talk about this often with friends and colleagues. The entire automotive OEM world took a huge turn in the late 2000s after the market crashed. It's extremely apparent when you compare new Toyotas to old Toyotas. Pre 2010 it's completely normal to see 400-500k miles out of any of them, anything built afterwards has just about as much service bulletins and failed parts as many domestic made vehicles.
After the market crashed OEMs had a bit of an eye opener and the focus shifted from making something that will run as long as possible requiring as little work as possible, to something that will run with as little issues as possible for the duration of the warranty for as little spend as possible.
Naturally failure rate will go up on any given part, but so do profits which is the main goal of any business. Stuff like this has been proven time and time again too, just look at GM's ignition cylinder recall and the Ford Pinto for example. The manufacturers admitted to knowing about these failure modes but didn't issue recalls earlier because it would have had large impacts to profit, so they chose to circumvent the issue or blatantly ignore it and it bit them where it hurt in the end.
For what it is, there are way worse issues to have than this cam phaser problem. I think in another 5 years from now people will really understand just how brilliant these trucks are.
