How hard is it?
Discussion in 'Ford Raptor Lighting Forum [GEN 2]' started by northerner77, Nov 8, 2019.
  1. northerner77
    northerner77 Full Access Member
    77
    24
    Dec 12, 2018
    Michigan
    Hey all, I am looking at the Baja Designs Pro fog light kit for my 2019. I have very little experience with any type of vehicle electrical work. I have read up here and watched a bunch of you tube videos. Is it really that easy to hook up for a novice or would it be best to find a local installer? I don’t mind tackling the work and would enjoy it, however, I obviously want to make sure it is done right. It just seems so easy but I haven’t connected wires like that before. Move forward based on ease of install or call the pros? Any other novice electrical guys do this and can provide your experience would be appreciated. Great site here, thanks all!
    hekster1 likes this.
  2. Speeddeacon
    Speeddeacon Full Access Member
    294
    145
    Nov 4, 2018
    NC
    I am not a mechanic and have no training at all, but I like to learn and do what I can to further my knowledge and skill set. That being said, the install is very simple. About the only skill you need is to be able to crimp connectors onto bare wires on the upfitter connections. Or, if you use the side tap that is provided with the Raptor upfitter harness then only need to be able to squeeze a set of pliers. I personally don't like side taps, instead choose to go with waterproof connectors like Weatherpack or Deutsch. The light end is a simple Weatherpack plug and comes pre-terminated with the harness that comes with the kit.
    The above will get you up and running and is all that is necessary. You can get a little more detailed by soldering the connectors, heat shrink tubing them, etc., but that is just taking it a notch further in quality and potentially adds a bit more weather protection, FWIW. There is really no reason to pay an installer to do this unless you just don't have the time. Plus it allows you to get familiar with the install should you want to change things up in the future.
    It really only gets more complicated if you want to run a bunch of relays or power distribution blocks, but those are for specific needs such as specific triggers and/or large numbers of high current lights, such as big light bars, etc.
    MDJAK and northerner77 like this.
  3. OffroadAlliance.com
    OffroadAlliance.com Supporting Vendor Supporting Vendor Supporting Member
    1,093
    477
    Mar 10, 2015
    Installing a set of lights like this isn’t real tough. The brackets are all bolt on and the wiring couldn’t be much easier especially if you’re using wiring harnesses like our Raptor specific one that is basically plug and play. The only real wiring you’d need to do is connect the harness the trucks aux switch wires. There’s quite a few write ups and videos on the process. Most people, any those that don’t do this stuff much, can complete a fog light install in 2 to 4 hours.
    Let us know if we can help with anything! We’ve got plenty of Baja Designs lighting kits in stock.
    PH 888-466-8991
    www.offroadalliance.com
    Bwdeluxe05 and northerner77 like this.
  4. melvimbe
    melvimbe Full Access Member
    1,319
    948
    Jul 22, 2019
    Having just installed reverse lights from @FordRaptorLights.com , I can attest that it's easier to install lighting than it may appear at first. I was rather cautious though and contacted @FordRaptorLights.com several times with questions, and they were always quick and helpful with answers. The lights are working great, and I'm going to complete the install but hooking it up to to upfitter switches this weekend (weather permitting).
    As already pointed out, there are instructions and helpful videos out there. One thing to remember, as pointed out, is there isn't just one way to do these things, and people are going to prefer certain methods over others. That means the how-tos will likely be a little 'loose' at times allowing for you to make your own decisions. I also have a couple neighbors nearby that work on their own cars, so if I ever do get stuck, I have a life line.
  5. realjones88
    realjones88 Full Access Member
    40
    205
    168
    Jan 27, 2018
    If you can use a wire stripper/cutter you are good to go. The connections can be wrapped together (lineman splice) and heat shrinked - no special crimping or soldering needed. Agree that it will take you 4+ hours your first time.
    Bryan Williamson likes this.
  6. COBRA90GT
    COBRA90GT Full Access Member
    753
    337
    Oct 16, 2013
    HOCKEYTOWN ® MI
    If you somehow manage to get in over your head with tackling the job yourself and live somewhat close to the Taylor/Metro Airport (DTW) area, give Joe a call over at Downriver Motorsports Wiring (734-288-3475).
  7. Fyatrk
    Fyatrk Full Access Member
    112
    18
    Aug 24, 2016
    I did the Rigid Design fogs last year at this time it wasn’t complicated took about 4-5 hours to complete only because I didn’t want to rush it hardest part for me was attaching the individual lights to the brackets as there was very little room to use tools under there as for the wiring I used the lineman’s splice method with heat shrink on top. I’m just across border from Detroit and s as m often over in Michigan a lot let me know if you need help if your not far from Detroit
  8. pbtjrlmrt
    pbtjrlmrt Full Access Member
    398
    259
    Feb 21, 2019
    Oregon
    I bought the same kit. Took mine to car toys and they did an excellent job for a reasonable rate...Did the rear lights at the same time....I also had them connect them to my high beam and the rocker switches..ymmv
  9. rhd555
    rhd555 Member
    12
    4
    Sep 29, 2019
    OK
    Well it wasn’t plug and play. Get a pro to do it
  10. 4x4TruckLEDs.com
    4x4TruckLEDs.com Supporting Vendor Supporting Vendor
    1,690
    698
    Jul 18, 2017
    It's not that hard. The hardest part is just getting the lights bolted in, as there's a lot of bolts (3 pairs of lights = 6 sets of bolts). You just need 2 wrenches (or a socket + wrench) so you can bolt things in. Then aligning the lights so you're aiming them where you want. And that's it.
    We sell a Baja Designs kit paired with some killer brackets from SPP. Our SPP Triple Fog Light Kit. This lets you pick/choose which lights you want from Baja Designs. The main difference between the "Pro" kit from Baja is just the wiring harness and the brackets. The lights are identical and you can pick the same lights in the Pro Kit. But the harness we give you is all-in-one. It's one harness to run from the lights to your upfitters. Everything is labeled and it's really easy. For the most part, plug and play. All you have to do is splice the connectors onto the upfitter wires and you are DONE. SUPER simple.
    We can help you pick/choose what lights to go with and help you with some tips/tricks during the installation. We stock a TON of Baja Designs and are happy to help. We're available via PM/Email/Text/Phone as well.
    Check out the Baja Designs kits with the SPP Brackets here: http://www.4x4truckleds.com/2017-ford-raptor-triple-fog-light-kit-w-baja-designs-lights/
    Here is a recent shot of our demo truck from this weekend running the Baja Designs Lights + SPP Brackets
    [​IMG]
Share This Page
