On the topic of oil sampling, it would be beneficial to have others performing the same testing. That way we'd be able to gather a broader data sampling and see any actual irregularities. Just a thought.
That's mighty interesting, @EIGHTLUG. I appreciate that information, however I doubt its applicability to street and off-road driving:
- Your diesel generators were designed for steady state operation. Automobiles don't operate that way. Off-road vehicles even less so.
- Diesel generators and gasoline powered engines are very different power plants, operate differently, burn different fuels, have vastly different compression ratios, etc.
- Diesel generators don't move, so they can have huge filtration systems. How big were the filters on those generators?
- Because weight is not a factor in stationary diesel generators, they can have huge oil capacities. Betcha your generators had more than 7 quarts of oil in them.
All of those will greatly affect the results of an oil analysis.
I use fully synthetic motor oil in everything I own, including the lawn mower. I really am a great fan of synthetic motor oil. I change oil at 6,000 mile intervals in my Raptor and my wife's Ford Edge. Following this scheme in several decades worth of previous vehicles, I've never suffered any kind of mechanical engine failure. I drove a 1986 Nissan D21 4x4 for 19 years and never had a failure. My method obviously works quite well. I trust my personal experience a LOT more than I trust the auto manufacturers.
Regular to synthetic is fine. Synthetic to regular is fine. As long as you're using the same weight either way will be fine. Technically it'll just be a synthetic blend.It looks like I've stumbled across some knowledgeable members. My question is straightforward. If the Raptor has 1qt leftover oil in it after it is drained, does this mean we cannot change the oil type as you are not supposed to mix oils? For example, from regular to synthetic?
You will not overfill your 6.2L when blithely pouring in a full 7 quarts of oil if you do this "one weird trick." (No, you won't get a bigger weenie.)
1. After the crankcase has fully drained, put the drain plug back in.
2. Pull the filter and let that drain fully.
Think your engine is now fully drained? Nope.
3. Empty your drain pan so you can measure how much more comes out.
4. Pull the crankcase drain plug again and watch in speechless astonishment as another 6 to 8 ounces drains out of the crankcase.
Automotive magic? Nope. Pulling the filter releases suction from an oil gallery and lets it drain into the pan.
Do this every time you change the oil. If you don't, you will systematically adulterate your brand new expensive synthetic motor oil with dirty oil, you'll probably overfill the crankcase, and your engine will never have a good oil change.
Here's another tip: Prime the new oil filter. Pour some oil into the new filter and roll it around in the filter to saturate the filter medium. You'll be surprised how much oil the filter medium will suck up. Put as much oil as you can in it without it pouring back out as you tip it sideways to screw on. Why? When you restart the engine after your oil change, you will have NO OIL PRESSURE until the filter is filled. Shorten the period of time your engine is running with no oil pressure by priming the new filter.
