GEN 2 Help! Gorilla like nuts spline socket split
squeak11
I was changing my wheels to my winter ones and half way through my rear wheel the socket split. I can't drive my truck until I get another one. Any ideas of which one fits and where I can get one? Also, the one that came with it was flimsy, is there a stronger one? TIA.
Sent from my SM-G960U using Tapatalk
BHook
search lug nut key on Amazon.
Local tire shop probably has one...
squeak11
squeak11
Thanks all for the help. Crisis is over! AutoZone 8 minutes away has them in stock.
Johnkn
LaPlata, MD
If the installation/removal tool split do you trust all the lug nuts that came with it? Not sure I would.
Steve R
Virginia Beach
Sounds like the wheels were over-torqued. The proper torque for the lugs is 140-150 lb-ft. Also, using an impact wrench on the lug socket can and usually does break them.
squeak11
squeak11
They were put on by hand as I helped them install my new wheels. I'm 5' 5" and 155 pounds and broke it using a 20" ratchet. No impact wrench involved. Maybe I'm just freakishly strong.
