help adding relay to auxiliary relay box
I'm installing a Hornblaster/Viair air system and want to utilize a empty relay spot in the auxiliary box to switch the air solenoid for horns using a horn signal and upfitter power, the same way as this guy in the link does it at 6:40 but with the relay plugged into the auxiliary relay box. Onboard Air & Train Horn Ford Super Duty F350 - YouTube
If you guys could help me with the wiring through the box, I would appreciate it.
Thanks
Yukon Joe
Russellville, AR
I was not able to figure out how to wire the horn, relay and upfitter switch all together. Therefore, I didn't use the horn. My aux two is the train horn switch.
Good luck. If you find a solution, please share.
Yukon Joe
www.RUNRAPTORRUN.com
