Great Functionality, Attractive Look, and Better Safety with New Lumen LED Tailgate Light Bar
carid
Cranbury, NJ
Check the new Universal LED Tailgate Light Bar by Lumen®. It is one of those rare occasions when a simple, affordable accessory can enhance the vehicle's appearance while also improving driving safety. The bar becomes an instant attention-grabber, especially when your turn signals are on. Even the most distracted driver behind you will notice flashy 3-stage ember turn signals. And when you need to back up, the reverse light will make the night as bright as day while also improving the operation of your back up camera.
The light bar has a sturdy waterproof construction and features three rows of LEDs: 1000 in total for a 48-inch bar and 1200 for the 60-inch version. It doubles the signals of your stock tail lights showing running lights, stop and turn signals, hazards, and reverse light. The installation is very simple, no drilling required. All you need to do, is clean the recess between the tailgate and bumper, apply ultra-strong 3M adhesive, and attach the lightbar. You can plug it directly into your flat 4-pin trailer wiring harness or buy an adapter if your truck has a round 7-pin connector.
Lumen® - LED Tailgate Light Bar
Notes:
The bar is not compatible with Ford's Blind Spot Information System (BLIS) with Trailer Coverage and Cross Traffic Alert.
Specifications:
Number of LEDs: 48” light bar – 1000, 60” light bar - 1200
Housing material: aluminum
Can be cut: no
Plug: 4-pin flat connector
Warranty: 1 year
Features:
Dazzling LED Sequential Turn Signal Display
Super Bright Reverse Lights
Weatherproof construction for reliable operation (IP67 ingress protection rating)
Dependable operation in any weather conditions (Working temperature range: -20°F to 170°F)
Easy Plug-and-Play Installation
If you have any questions, feel free to ask them in replies or in private messages.
Also, you can contact our technical experts in Live Chat at CARiD.com or simply call 800-505-3274 (tall free).​
pastorwug
Santa Maria, CA
I don't think I'd care to have this plugged into my trailer receptacle all the time. I love the BLIS capability and it sounds as though this device turns that off because the truck thinks there's a trailer attached. Not for me.
carid
carid
Cranbury, NJ
Today we are back with a new video, dedicated to its installation. Our tech expert Greg will guide you through each step, with all the tools needed and detailed explanation of the whole process.
Finish off the look of your truck and make it safer with Lumen LED Tailgate Light Bar!​
Sam Richmond
Alabama
My question is has anyone had a problem with this light bar where one turn signal (my case Left turn signal) works most of the time but often works for about 3 -5 blinks then turns off the rear turn signal on both truck and light bar I checked connections all look good?
