GEN 2 Front end collision warning
vetdog
Seems like this rarely warns me of anything. Not that I’m constantly flying up behind someone but I have tested it on sensitive and it doesn’t alert most of the time. Anyone else having any issues with this? 2017 SCREW
squeak
I have a 17 screw and mine seems to work pretty well. Typically it goes off when someone in front of me is going to turn and I'm going straight but it works. I've never messed with the settings.
Sent from my SM-G930V using Tapatalk
HunyaKitti
My goes off frequently, but then again I'm driving around Fort Bragg and people abruptly swerve everywhere all of the time.
Sent from my Pixel 2 XL using Tapatalk
I’ve found that if you are on the gas and the truck detects a vehicle decelerating in front of you, or turning right if you are coasting, you’ll get the alert - I do anyway. For me, it seems to alert for right turners most often, but if you’re applying throttle and there’s a 12 o’clock vehicle slowing it seems to alert consistently for me.
cdurbin
Lebanon, IL
Mine seems to alert primarily when I am actually giving the vehicle gas and someone slows/pulls out in front of me.
If I'm coasting I've only had it go off once when someone pulled out in front of me.
-Corey
salts001
Northern New Jersey
It alerts me non stop probably due to the crazy nyc driving. I also get the warning from time to time when coming around a curve...maybe a bit too fast :biggrin:
ameration
Ohio
Is this on all Gen 2’s or only the ones with the Technology Package Option?
V
vetdog
Not sure but mine only kicks in either randomly or not when it should
