Omani-Raptor
Hi, just wanted to know if the following is normal driving under 2wd:
One axle rotates rotates forward and other axles rotates backward !
Your front axles should not spin unless you have a leak in the actuator and it is allowing the axles to engage. It does not mean that your in four wheel drive though. Only the hubs are locked up. In 2 wheel drive they should not spin at all. They are vacuum actuated and it means you may have a leak in the vacuum lines.
Mil T
