Fox live valve upgrades
gordo
Ft Liquordale
Maybe a stupid question but can you add a reservoir to the oem live valve?
tltoronto
toronto ontario canada
To the fronts? You cannot. Look at the design on the oem, the shock shaft is on the top of the body, versus aftermarket where the body is above the shock shaft and allowing a reservoir to be mounted to the body. What is an interesting question is wether the new remote reservoir front live valves are compatible with your system.
adllewis42
Seattle
Why wouldn't they be?
Loufish
Burbank CA
For what it's worth, the OEM front shocks (Live/Non Live) have a small reservoir inside...there is a internal floating piston separating the oil from the nitrigen..so they are not Emulsion shocks...
The reaper
NJ
Another stupid person with Stupid question will OEM live valve shocks work on an older raptor ?
